injector question
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
injector question
Hi All,
Does anyone know if 22lb injectors from an '87 350 will work on a '90 350?
thx
thx
Originally posted by D's89IROCZ
Yes they will .
hay rich !
Yes they will .
hay rich !
Those 24s I bought sprung a leak
so am looking to get some factory spec injectors. Senior Member
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Email rich @ Cruzin Performance & ask if you can have it replaced while he cleans a flo-matches the rest of them.Then you will have a set that's within 2% of each other while the stock injectors can be off as much as 7% and still be cheaper than buying a new set
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Or a local option is KW fuel injectino. I had my 22l'b ones taken there . Psyonically ( sp lol ) cleaned then flowmatched for just over 200 dollars
