edelbrock runner gaskets?
Old Mar 10, 2006 | 04:34 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
What does everyone run for a top gasket on your edelbrock runners. The "edelbrock" $40.00 runner set only gives you the lower gaskets. Good "kit"! I called and they said run the stock gaskets and open them up. Great, but there tin in between the fel pro gaskets. What is everyone else doing?
Old Mar 10, 2006 | 06:34 PM
BadSS's Avatar
Mr. Gasket #146 - 1.75" runner gaskets, top, bottom, and T/B gaskets - $18.39 from Summit
http://store.summitracing.com/defaul...=egnsearch.asp
Old Mar 10, 2006 | 06:56 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
you will still have to use the edlebrock lower gaskets because the mister gasket set will not work on the lower edlebrock runners. i found out from experience.
Old Mar 10, 2006 | 07:06 PM
Rob Wade's Avatar
You would think for 40 freekin bucks the gasket set would be complete. It does list it as "edelbrock runner gasket set"!
Old Mar 10, 2006 | 07:14 PM
87zjeff's Avatar
i would tend to agree, but like you, i found out the hard way.
Old Mar 10, 2006 | 08:43 PM
BadSS's Avatar
I've used these gaskets with a slight trim on stock intakes with SLP and ASM runners. Out of curiosity,,, what was the problem with the Edelbrock runners? I've never bolted on a set, but was thinking I might get the next guy wanting me to work a set of runners to get the Edlebrocks.
Old Mar 10, 2006 | 08:49 PM
87zjeff's Avatar
i have an '87 so the port on the passenger side, the small tubewhich is i believe either an egr port or an idle air port, is made differently on the edelbrock runner. the mr gasket causes a vacuum leak cuz the port on the runner is angled strange. even stock lower gasket wouldn't work.
Old Mar 11, 2006 | 05:48 PM
Rob Wade's Avatar
Do the Mr gasket upper gaskets have tin in between two layers of material or are they just material?
Old Mar 11, 2006 | 07:04 PM
87zjeff's Avatar
just material
Old Mar 11, 2006 | 10:56 PM
BadSS's Avatar
Thanks for the info. I appreciate it.
Old Mar 12, 2006 | 08:09 AM
Rob Wade's Avatar
Thanks Jeff. I'll pick a set up at summit while i'm there.
Old Mar 12, 2006 | 10:06 AM
87zjeff's Avatar
not a problem guys
Old Apr 22, 2006 | 04:24 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Hey guys, just wanted to clarify. ..
So I need to buy both kits?? EDL-3866 (bottoms) AND a set of stockers just to get the tops??
And then they BOTH need to be opened up?
Edelbrock doesn't sell a set of top pair already opened up?
Any other options?
Thanks.
Old Apr 22, 2006 | 11:02 PM
87zjeff's Avatar
the edelbrock set(lowers) are the same size as the edelbrock runner. they will not need to be opened up unless you port the runners. if you go ahead and get the mr gasket set for the tops, they don't need to be opened up either unless you port the edelbrock runners. stock uppers will need to be opened up for use with edelbrock runners.
Old Dec 4, 2006 | 11:37 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
Any other options?
Thanks.
From the looks of everything, you just buy 2 of the Mr Gasket 146 kits. You need 2 of the driver's side lower gasket to fit the Edelbrock runners.
$36 + shipping from Summit
Old Dec 5, 2006 | 08:05 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
ah ****
i ordered the slp gasket set for my edelbrock runners.. i figured yea they may need a little trimming, but i didnt think there would be angle differences and stuff...crap
Old Dec 5, 2006 | 08:57 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Whats the PN# for the SLP gasket set? Every time I search on summit I get results that I'm not sure about (i.e. no description and vague product name)
Old Dec 5, 2006 | 05:36 PM
Rob Wade's Avatar
Call summit and ask for the Mr Gasket set. They are 1.75" and half the cost. They have them in stock. I got some this summer. If you use the stockers they have tin in between two layers of gasket material and are hard to open up cleanly!
Old Dec 7, 2006 | 05:24 PM
Car: 1991 Z28
Engine: SBC
i ordered the set directly from SLP...20$ gets you all the gaskets and i just got em tn...same issue..passanger side doesnt work
25$ down the drain..
Old Dec 9, 2006 | 01:39 PM
RGV 89 GTA's Avatar
Car: 2001 SS/1989 GTA
I used the stock gasket on the upper edelbrock runners and just used a dremel to open them up.
Old Dec 9, 2006 | 04:48 PM
87zjeff's Avatar
i just found out for a fact today, order two sets of the mr. gasket sets and use those for the edelbrock runners. two drivers side lower runner gaskets works like a charm
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Pac J
May 17, 2020 10:44 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
