Please Help Me Find Intake gaskets & Materials
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Im about to put my inatke back on my car and I need to know what to buy and the best ways you guys like to install your gasket. Ive herd not to use any type of gasket maker because of gasoline messing them up and also no copper type of gasket maker. So what do you guys use that works best.
Any thoughts?
I would also like a set of intake gaskets that have the bead of "Printoseal" around the ports already so I don't have to worry with it. The problem is im looking around on summit and can't seem to find the ones for my car so if someone could point me in the right direction that would be great. The gaskets need to be for a stock 5.7L TPI.......I aslo alrdy have all of the upper intake gaskets so no need for a whole intake gasket kit for the TPI system.
I have some summit bucks so I wanna order from them so if someone could list the parts and part# that would be alsome.
http://www.summitracing.com/
Any thoughts?
Engine: 350 HSR
Axle/Gears: 3.42's
http://store.summitracing.com/partde...0&autoview=sku
These are the gaskets I need but I can't find them as a single intake gasket set. Ive alrdy bought the upper intake stuff I just need the intake gaskets.
Im loosing my mind
Im loosing my mind
Engine: 350 HSR
Axle/Gears: 3.42's
Part# FEL-MS90314-2
EDL-7201
MRG-810G
Any of those work?
I really need to find the ones I need so I can order today. I would really hate to buy that whole upper intake kit from felpro.
Please Please Please Please Please!!!
EDL-7201
MRG-810G
Any of those work?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Just go to a parts store.
I know for sure that at:
Carquest: you can get upper runner gasket set, or lower intake set.
Autozone: U can get the runner set or intake gasket set(they are felpro to)
Advance: Used to be same as above, but I belive they carry different gaskets now, so im not sure.
later
Jeremy
later
Jeremy
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
