wont keep running
Old Mar 12, 2006 | 04:05 PM
LKJR's Avatar
wont keep running
ok guys I'm in the middle of this TPI swap on a mild 350 and i'm stumped.
Problem I have is, I can get the engine to start but it won't stay running. Will, start, and I have good fuel pressure, but what seems like is when the injector banks fire the fuel pressure drops a lot, like 9-10 lbs or so, you can watch the gauge drop every time it fires. Also it seems like when the banks fire it's loud. I can heard a loud tick noise, is that normal. Well after it fires it will run for 10-15-20 seconds or so then die like lack of fuel.
is this a bin issue? I've got a prominator in there but I just loaded a bin file for test purposes and don't really know much yet about modifying that. any suggestions on what bin I should be running?
Old Mar 12, 2006 | 04:48 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Make sure you have the correct ECM, and that the injectors are for a 350(meet your fuel requirements), and that you have the correct 350 bin/chip. Is the system from an car that was originally equipped w/ a 350.
Old Mar 13, 2006 | 07:37 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
What IS the actual fuel preasure? I had 22 lb injectors on the 350 running the 305 .bin before. I don't see that being the issue.
Make sure you find out exactley what that tick is .... rockers ? Why the injectors would tick really loud is new to me . But you sure it's not also an exhaust leak?
Old Mar 13, 2006 | 01:18 PM
LKJR's Avatar
I don't think it's the rockers ticking but it's possible I'm fighting oil leaks on cheap valve covers too so who knows. I don't think it's an exhaust leak but I wouldn't rule that out, the truck has sat for 2 years so anything is possible. The system is from a 305 but I changed the injectors out to the larger injectors.
I don't remember which bin file I have loaded that's why I was asking for file suggestions so I could try a different one.
Old Mar 13, 2006 | 03:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
you also need a 350 knock sensor too .
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
