Different weight stock 305 pistons, different crank balances?
Old Mar 13, 2006 | 05:52 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I am putting a 305 together in a pinch. It needed pistons, and I have a set of pistons and rods ready to go but they are around 30 grams heavier than stock (for the entire rod/piston/pin/rings assembly). These replacement pistons are actually used std bore 305 pistons from a 1983 engine. They are going in a 1987 TPI engine. I know I will lose half a point of compression but I don't care at this point. Would the 1983 engine with the heavier pistons have had the crank balanced differently from the 1987 engine with the lighter pistons? I am pressed for time and this engine will see low rpm daily driver type use only, so I am tempted to just use the slightly heavier pistons. The heavier pistons are within a few grams of each other for the set of 8, but heavier than the correct ones for this 305 engine. Balancing the rotating assembly is absolutely not an option, I could get a set of the correct pistons for much cheaper, but I'd rather use these since I already have them.
Old Mar 14, 2006 | 11:03 AM
Vader's Avatar
If the crank were balanced to the reciprocating mass as an assembly, it would be balanced differently. In a street engine, it might not matter. Is a used 350 crank an option?
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
