Vacuum Problem
Old Mar 13, 2006 | 06:43 PM
lyllibido's Avatar
Vacuum Problem
I have checked for a vacuum leak; looked for cracked lines; loose connections; can't hear any hissing & also checked with starting fluid...could not find it. When I turn on the air (not the a/c), it blows through the defrost vents. When I turn it to A/C, it works fine, it will blow through the vents. Any suggestions? Thanks.
Old Mar 14, 2006 | 01:25 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Try pulling the actual climate control head unit out and look at it.
The vacuum lines attach to the back of it as well as the cables that control the heater box flaps.
I believe the T line back near the pass rear of the intake with what looks like a little cansiter(believe its a check vavle actually) in the line is the one that supplies vacuum into the car for the HVAC controls.
later
Jeremy
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mustangman65_79
Aug 8, 2015 12:07 PM
