fuel ratio
Old Mar 14, 2006 | 10:50 PM
me2's Avatar
me2
Transmission: 700r
Axle/Gears: ford 3.55
fuel ratio
I am going to make a 3000 mile trip.
How lean can a 350 with a 700r run at 60 to 75 mph without damaging the engine?
me2
Old Mar 19, 2006 | 01:14 PM
brutalform's Avatar
What is your reason for this question? What problems are you experiencing? There are alot of factors involved. RPM, load, etc. Generally 14.7 is stoich, where all the air and fuel is consumed in the combustion process. At cruising speed, the AFR might be at anywhere in the 14.5 to 15.1 or even as lean as the 16.1 range. Having the engine lean in the medium to higher engine loading, is where the problems start.
Old Mar 19, 2006 | 01:21 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
What he said.
U wont find it out until you experiment on your own engine.
Even to seemingly identical factory cars might do best at different AFR's and timing.
Some combinations dont like highway mode and some take to it like it came that way from day one.
I generally add a couple of degrees of timing and start around 15.5 or so AFR when doing testing.
U might have to play a lot to make it happy or see some results or you might see them right away.
Tons of info on the prom board about highway mode and great info in the stickes there as well.
Assuming your car is still injected of course
later
Jeremy
Old Mar 19, 2006 | 09:56 PM
me2's Avatar
me2
Transmission: 700r
Thanks for your help.I will be traveling from Mazatlan Mexico to Fort Wayne Indiana, a 3000 mile trip.This will give me about 5 days on the road to fine tune the accel computer on a TPI chevy 350, 700r with tc lockup and a 3.55 ford rear end in a nissan hardbody pickup. 14 mph realy sucks.
Thanks again for your help,
Me2
Old Mar 19, 2006 | 10:02 PM
me2's Avatar
me2
Transmission: 700r
Sorry for the errow in the post. It should have been MPG not mph.
beastin91rs
Oct 9, 2015 07:38 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
Regal105
Aug 23, 2015 03:45 PM
happyhapka
Aug 15, 2015 04:42 PM
