Swapping injectors, what tools do I need?
Car: 1994 Trans Am
I read that I need a special tool to remove a pin or clip? What is it's name? And can I buy the O-rings at Autozone or Checker? Anything else that I will need?
Well when i did mine i had to remove the plenum and runners.
Then you need to rmove the fuel rail with the injectors...
Going to take some time.
My biggest problem was breaking tools as i tries to unbold the runners. Then i got my hand on a torch and was way easier to unbolt.
You will need to get orings for the fuel rail. they were cheaper at GM
/Sam
/Sam
Car: 1994 Trans Am
Thanks, I have to remove the intake to replace the gasket underneath. So the O-rings are for the fuel rail not the injectors? What tools did you break unbolting the runners?
Street Lethal
Apr 30, 2019 12:14 PM
383backinblack
Aug 15, 2015 06:36 PM
