Cast Iron vs Alloy
Old Mar 23, 2006 | 02:32 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
Cast Iron vs Alloy
G'day guys and Girls.
Other than the obvious weight saving, what are if any, advantages to going alloy over cast iron heads. Given the same head design.
Old Mar 23, 2006 | 02:39 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
http://chevyhiperformance.com/techarticles/83858/ take a look at that. should do some answering
Old Mar 23, 2006 | 03:14 PM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Axle/Gears: 3.45
That about somes up
1. what I thought and
2. what I wanted to know.
Cheers
Old Mar 24, 2006 | 08:01 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
HI AUSSIE, I think the alum. it the way to go, even it you have the same flow rate as the steel, you can get some advantage by being able to run higher compression with the same fuel, and that will pick you up some power, also the weight savings will make a nice difference and the best thing is, if you ever hurt them they are easy to repair. Im not saying that the steel units are bad but I think with the quality and price now for an alloy head today it just makes good sense. Good luck on your choice and just do some research and make a good decission on you runner volume and chamber size... remember on heads bigger is not always better, just like cams and induction you should choose the components that will work with each other.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
skinny z
Oct 5, 2015 06:23 PM
Jynx88
Oct 4, 2015 08:19 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
