tpi intake manifold leak!
Old Mar 23, 2006 | 07:43 PM
screamingz28's Avatar
Car: 85 Z28
Engine: 305 LB9 TPI
Transmission: TH-700R4
attention everyone, i need advice on the easiest way to take the intake manifold off the engine to fix a leak. i want to avoid taking out the distributor. the hole is letting out coolant near the passenger side by the valve cover. it is a small hole but it's letting out enough coolant to make me feel uncomfortable about driving it. i need advice fast. please can someone help me out.
Old Mar 23, 2006 | 09:59 PM
mcwpns's Avatar
Car: 1989 firebird/91 tpi formula
Engine: 327 small block/305 tpi
Transmission: 700 R4
Axle/Gears: superior axles/3.42's
Sure it's the intake? If your taking the lower intake off, the distributor will have to come out since it is bolted to it. You can take the distributor cap off and mark the position of the rotor on the distributor housing and mark the housing to the intake manifold. Pull it out and when you go back together line all the marks back up. If that does not work you will have to time it. Pull the #1 plug and bring the motor up on compression stroke. Use the timing mark on the balancer to make sure it is on top dead center. Drop the distributor back in and point the rotor directly pointed at the #1 cylinder. Then you will need a timing light to set it at 6* (stock position) or around 10-14 (for performance). Don't forget to unplug the timing wires for the computer---should be located around your heater box should be a 2 wire connector 1 brown and 1 black if I remember correctly. It sounds like alot but it isn't that difficult.
Old Mar 23, 2006 | 11:29 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Remove distributor cap. What part is that? The part where the spark plug wires attach?
And with what do you mark it with, magic marker I'm guessing?
Now how do I go about installing it back in? Do I turn it until all the lines match up?
1992rs/ss
Jan 31, 2025 05:10 PM
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
