how do you polish the TPI
Old Mar 24, 2006 | 12:32 AM
skinwalker's Avatar
Car: 1989 IROC Z
Engine: TPI 350
Transmission: 700R-4
So how do people polish there TPI's? Cause Im thinking about doing it to mine but I need to know how it is done.
Old Mar 24, 2006 | 12:38 AM
Bluejae's Avatar
Car: 1988 Formula 350
Engine: L98 350 TPI
Transmission: 700-R4
Here's a link to a good tutorial wrote by someone who has already done it, he also has alot of great advice on other stuff too.
http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm
Old Mar 24, 2006 | 10:12 AM
AussieGTA's Avatar
Car: Trans Am GTA
Engine: 350TPI
Transmission: T700R4
Axle/Gears: 3.45
Another Idea that you may want to consider, comp coating. Its not that expensive and you won't have to polish it every couple of weeks. Just wipe it down and its back to pretty and shiny.
Old Mar 24, 2006 | 10:50 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
That and polishing them takes a long time and a lot of patience. I just polished the flat top part and the fins and had the cracks between the fins and the rest of the sides, runners, intake, etc. powder coated gloss black (or whatever color you want to do). They make a powder coating that looks pretty close to a polished aluminum also as Aussie said.
If you want to polish the whole thing though, make sure you buy the aluminum distributor/coil cover for the back of the plenum. The one Firebirds/Camaros have are plastic. I guess Corvettes came with an aluminum one. That way the polish is complete all the way back. I've seen them online and Im sure you could probably get one at the Chevy dealer as well. Good luck.
86IROC112
Sep 29, 2015 04:07 PM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
