what can cause back fireing
Car: 89 IROC, 85 Z28
Engine: 350 TPI, 305 Carborator
Transmission: 700R4, none
i have a 89 Iroc tpi setup and over the past few weeks ive gotten it to run fairly well but it still backfires. Ive got new plugs wires cap rotor O2 sensor and a few odds n ends, its timed to 6deg and i just cleaned the IAC wich greatly helped the fast idle.
but anyways drivin it around today it was runnin good (not great, its still lackin a bit of power) and after about 45 min it started backfireing. so if anyone has some suggestions im up for em
thanks
thanks
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Backfire from the intake is lean, Backfire into exhaust is rich.
my back fire is comming from the exhaust so i would be runnin rich. isnt it the O2 sensor that helps decide the fuel mixture. i just replaced the one thats in there now, is there a way to test it to check if its all right. or is there another sensor that i should be woried about for the fuel mixture. i do notice a faint unburnt fuel smell every now and then. thanks for the help peeps, ive been reading the forums but without a search function curently its hard to find what im lookin for
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My car did this one day, with no SES codes. About an hour later it threw a code 34 (MAF). And when this happens, the ecm makes the exhaust super rich. Rich enough where its blowing black smoke at idle.
Car: 91 formula
Engine: 350 tuned port. bolt ons
check your ignition coil i had a cheap coil on my car thing was backfireing like crazy change it out for a better one and its fine.
so i tested my coil and it failed one of the tests. i installed a new one and it greatly helped with the backfireing, i only get small pops everynow and then, before i was gettin bangs (i actually had a backfire that blew a hole in my muffler) that shook the car. the new coil didnt help with the unburt fuel smell though
so i guess my question is would a faulty MAF give me these problems, or something else, the MAF i have on there looks like its brand new (its the only thing under the hood with stickers) but its a bosch. im not to sure about bosch stuff i usually get delco for my cars, does bosch make a good MAF
