AIR diagram
Old Mar 24, 2006 | 02:37 AM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
Transmission: 700r4 w/ shift kit and 2500 stall
Axle/Gears: 2.77 one tire fire!!
AIR diagram
does anyone have a diagram showing how the AIR tubing is routed? im re-installing mine to pass emissions and have no clue how to route all the hoses....any help will be greatly appreciated
Old Mar 26, 2006 | 04:13 PM
Vader's Avatar
'89 RS? TPI? This IS a TPI forum...
Old Mar 26, 2006 | 04:53 PM
Jza's Avatar
Jza
From the AIR pump to the diverter valve inlet.
From the diverter valve the side with the green connector goes to the two exhaust manifolds. The other side (white connector) goes to the catalytic converter.
The last hose on the diverter valve goes to atmosphere.
Old Mar 26, 2006 | 10:18 PM
riphc06's Avatar
Car: 89 Camaro RS
Engine: 350 TPI L98
the diverter valve is the piece that hooks up to the smog pump via a metal tube correct?
83 Crossfire TA
Jan 3, 2016 01:26 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
edoff13
Sep 11, 2015 03:55 AM
snakeshooter
Sep 10, 2015 07:46 AM
