iac bypass
Old Mar 25, 2006 | 04:35 PM
joeyg329's Avatar
Car: 88 iroc/383 82 regal/sonoma 4.3 5sp
Engine: 5.7 tpi/383/4.3
Transmission: 700r4,th350,t-5
iac bypass
heres one for you guys: i never got my car to idle good with the cam and the underdrive pulleys.. . well i was going through the minimum air adjustments and reset the iac and started it with the iac out all the way and unplugged. . car runs at a smooth 800 idle, cold/warm, in gear or not. can i leave it unplugged??? the car runs the same, just idles better. will this affect anything besides gas mileage?? im not worried about the mileage change, but i love the idle it has now haha....thanks
joey
Old Mar 26, 2006 | 04:19 PM
Vader's Avatar
Sure. You can keep it unplugged. Just don't be concerned when you start it cold (when it's cold outside), or turn on the A/C, or the electric fans turn on, or when it afterfires on hot deceleration, or when you're trying to maneuver into a tight parking lot and it stalls, etcetera.
The proper way to increase the RPM is reset the minimum air to factory specs, then program the target idle where you want it.
Old Mar 26, 2006 | 06:08 PM
joeyg329's Avatar
yeah i figured it wasnt that easy of a fix. . . i didnt experience any problems like that but im sure they will arrise soon. . . seems like the answer to all my problems is getting the right chip burned. . . damn tbichips.com haha
thanks vader
Old Mar 26, 2006 | 10:47 PM
Vader's Avatar
It's actually fairly easy and inexpensive to burn your own. The editor software is free or at a minimal donation cost for TunerPro. A Pocket Programmer II is reasonably priced at around $180 new, or even less at auction sites like eBay:
http://cgi.ebay.com/Intronics-Pocket...QQcmdZViewItem
The rest of what you would need is found right here, in the DIY-PROM Forum.
$750 L98
Feb 1, 2025 02:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
Formula8r89
Sep 22, 2015 04:24 PM
