Fuel sending units
Old Mar 25, 2006 | 05:55 PM
mksp89IROCZ's Avatar
Car: 86,86,89, all IROC-Zs
Engine: 305cccarb,3sumtin,305 tpi
Transmission: 700R4s
Axle/Gears: 2:73open,3:42posi,2:73posi
Fuel sending units
I have a question concerning the hookup of the fuel pump on the sending unit. I am replacing a hacked up TPI sending unit. I have a TBI unit and noticed the difference in the hookup. I assume due to pressure. The difference is the TPI has a sleeve like hook up and a reduced end on the tank mounted tubing The TBI doesn't. My question which you may already know is will a TBI work with the TPI? I was able to push the sleeve up on the TBI but it was tighter. Let me know what you guys have experienced. I am planning on putting the TPI back in it. I have also thought about a carb line. This would give me the flexibility to use what ever pump and pressure for what ever type of engine with an external pump.
Thanks.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
