Corvette L98 heads
Old Mar 26, 2006 | 04:48 PM
IndyZd's Avatar
Car: 82 IndyZd 88 IROC 84 Z28
Engine: 305 5.7 305
Transmission: auto auto auto
Axle/Gears: 2.93 G92 3.27 3.23
Corvette L98 heads
The search is down right now so here's my question
Is there any advantage of the corvette L98 heads over the cast version on my 88 5.7L?
I know with the aluminuim heads u can run more timing, better cooling and the weight savings are all a plus, but what about the compression ratio, valve lift etc.....?
What about the stock cams? Much different.
I was told these are the same heads as on the ZZ4 crate engines and they are rated at 355hp. What do I need to do to get that rating?
Looking for some good info on this comparison..Thanks
Old Mar 27, 2006 | 12:21 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
I know that the stock L98 heads have the 64cc combustion chambers, and with the vette' heads 10088113 they are at 58cc combustion chambers, the compression ratio jumps quite a bit around the 10-10.4 range, just make sure the head hasn't been decked or warped. Got mine from ebay special $575 later. Not sure about valve lift, still lookin that up.
More info would be appreciated.
Old Mar 27, 2006 | 12:32 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
the higher compression ratio will need more premium fuel usually. but 10-10.5 to 1 on aluminum is usually where u want to be anyway.... but combined with stock cam and 1.6 ratio rockers.. you'll see some good gains. they flow just abit better than the iron heads.
other than that i'd sooner go vortec heads and find a baseplate for them. vortecs new are same price as L98 vettes new, but they flow better. just need new manifold, thats all, which on tpi is abit more money.
Old Mar 27, 2006 | 09:23 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
With the aluminum L98 heads, you also get screw-in rocker arm studs which will give you more freedom with cam/valve spring choices...
Old Mar 27, 2006 | 12:39 PM
No guideplates though...
Old Mar 27, 2006 | 01:43 PM
stubbs's Avatar
Car: 1987 Corvette
Engine: 383 TPI
Transmission: 4+3
You can find good deals on them. I just sold my 87 Aluminium heads for 408 dollars, so the deals are there. If it was me I would go with 88 and up D port heads, big difference.
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
CRFred
Feb 7, 2016 11:39 PM
TreDeClaw
Aug 14, 2015 06:58 PM
