which roller cam should I buy!
Old Mar 26, 2006 | 05:52 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I just smoked a comp cam with hydraulic lifters. it had 464/470 of gross lift.
the power range was 1500-5500
This time I would like the power range to be 1200-5200
The main culprit was the tv valve that downshifted into third and my shift kit that told me remove the mtv spring out of the valve body.
Old Mar 26, 2006 | 06:15 PM
jamon8's Avatar
Engine: 350 tpi
its a 305 that might not last that long. the heads have some port work. the tpi is stock with work done to the upper plenum.
I would also like to have this cam work with the next motor that build. a 350 or 383 10 to 1, aluminium heads, edelbrock base and runners.
I have edelbrock tes headers and 3 inch back.
basically I want a cam that will work with the next motor even though it will be a little too much for the 305.
junkcltr
Aug 2, 2019 11:12 PM
gixxer92
Sep 1, 2015 04:32 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
