So, What exactly happens when your car enters limp mode?
Old Mar 27, 2006 | 08:09 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
I tried doing a Google search, but didn't come up with much for of a definitive answer.
What exactly does the ECM do when it enters limp mode? Turn electric fans on, high idle, fixed timing? What else?
I'm, trying to figure out if my ECM is shot, it doesn't prime the fuel pump, nor does it give any codes when you ground out the diagnostics wire (SES light is on constantly, electric fans run constantly), or if it is just cause I don't have a memcal installed. I am not trying to start the vehicle, just wanted to see if the ECM was hooked up correctly, and also make sure that all the sensors are sending readings that make sense.
I do have a spare ECM, but I know this one worked prior to me installing speed density, so if I did fry it, I need to know so I can hunt down what killed it.
Old Mar 27, 2006 | 09:02 PM
Vader's Avatar
Originally Posted by 80Sierra
...or if it is just cause I don't have a memcal installed.
Yes. If the ECM does not perform a succesful POST with ROM checksum for the MEMCAL, it goes directly to backup mode. In your case, without a MEMCAL installed, it doesn't have backup chips, so it probably won't even run.
Old Mar 27, 2006 | 10:34 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Cool, I'm gonna borrow a buddy's 5.7 memcal (won't be able to start due to VATS) but that should let me know if that is infact my whole problem (which I did suspect from the start, but wanted to make sure )
Old Mar 29, 2006 | 09:01 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Alright!
I went ahead and borrowed the memcal, put it in, and sure enough, everything seemed to be working correctly.
However, I did find one problem that is still there. The ECM is not delivering any ground to the fuel pump relay. I know that the wiring is good up to the ECM, as I can manually ground that pin and it immediately turns the pump on.
Does this have something to do with the VATS? Or is my ECM still fried?
Old Mar 29, 2006 | 09:14 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
VATS disables the fuel system if incorrect key resistance is found...
Old Mar 30, 2006 | 12:16 AM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Axle/Gears: 4.10
Perfect, thats what I wanted to hear
Now to make myself an adapter / buy one from moates so I can disable VATS, AIR and the EGR in the prom, along with telling it that it now has 19 lb/hr injectors, and see if she'll start
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
