MAF EGR compatable with SD?
Old Mar 29, 2006 | 12:02 PM
80Sierra's Avatar
Car: 80 GMC K35
Engine: TPI 355
Transmission: NV4500
Axle/Gears: 4.10
Hey guys!
I'm just doing the finishing touches on my speed density conversion, but just thought of something I didn't before. As far as the EGR goes, can a guy even use the old MAF EGR with the new speed density ECM? The newer ECM doesn't have the EGR temp switch etc, or should I save myself the trouble of routing the EGR wires / vac lines and just use the old EGR as a blockoff plate?
Old Mar 29, 2006 | 09:22 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you shouldn't have any problem using the old EGR valve.
if i remember right the SD systems turns the EGR off & then back on at certain times & looks for a change in the MAP reading to see if its working.
tmellott89
Oct 14, 2015 02:06 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
