1.6 roller rockers
Old Apr 1, 2006 | 03:11 PM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
1.6 roller rockers
I want to get some 1.6 Comp Cams Pro Magnum Roller Rockers for my 1990 Trans Am and have already done a search but it didnt yield any really helpful results. My question is what all is needed to install these rockers? Do I need to change studs or anything else? Maybe valve covers? And is there a link to a helpful install guide?
thanks for your replies!
Old Apr 1, 2006 | 04:58 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you will need to get the 3/8" self-aligning style rockers. that's pretty much all you need to know. with the stock cam, nothing should need to be modified. i'm running a set of 1.5 pro-magnums and i love them.
Old Apr 1, 2006 | 05:10 PM
Car: 1990 Trans Am
thanks a lot. Also, did you notice much of a difference with them? Does anyone know the part number for the self-aligning 3/8in Pro Magnum Roller Rocker Arms?
Old Apr 1, 2006 | 06:27 PM
mw66nova's Avatar
Engine: 7.0L
i built the entire motor together so i couldn't tell you if there was a difference. i'll tell you though that a 1.6x 60' time is a FUN ride...12.16@110mph with the new motor so far!
Old Apr 2, 2006 | 09:41 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Youll have to modify the stock valve covers to get them to fit over those rockers. Not too hard -- I did it, just search on here for "pro comp stock covers". if you dont the little webs inside the covers will hit the rockers cause they are wider than the stamped ones.
Old Apr 5, 2006 | 06:24 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
what if im runin a .487-.495 lift cam? i have upgreaded springs but runnin the stock cast heads i have 1.52s now but is goin 1.6 to much on stock heads with that lift?
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
