SLP runners porting question
Old Dec 12, 2005 | 07:31 PM
Destructive099's Avatar
Car: Dark Blue 1987 Chevy Iroc-Z Camaro
Engine: 5.7 350
Axle/Gears: 3:42
Im looking for some tips what tools to use or even someone that has done this. Im planning on buying the SLP runnings and porting them out since they have so much extra material. Anybody with pictures or ideas id appreciate them alot, thx.
Old Dec 12, 2005 | 08:52 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
You need to search. There are some great past posts with this information.
Old Dec 12, 2005 | 09:14 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Look around here http://www.ruffstuff.com/
You'll want a die grinder that handles 1/4" shank bits,
and at least one mandrel for sanding cartridges, and of course the cartridges (sanding rolls).
If you use an electric die grinder then you'll need a dimmer switch to control the speed. This is a must have with electric.
Old Dec 13, 2005 | 07:54 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
305sbc - You're right about using the dimmer switch with the electric die grinder. I ported quite a few intakes, runners, plenums etc. using an electric without some type of modulating switch. Let me tell you, a 1/4 hp electric grinder is a serious tool.
For my last project I bought a Dremmel foot pedal that worked great!
www.geocities.com/dzperf
Old Dec 13, 2005 | 09:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
heres a great thread of what u could do to get max performance out of the runners
dyno results are in here
https://www.thirdgen.org/techbb2/sho...hreadid=333424
pics of modded runners are in here
http://para.noid.org/~thresher/images/albums/082901/
Old Apr 5, 2006 | 04:28 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
anyone else have pics of there slps ported
Old Apr 5, 2006 | 05:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Sure, why not. Huhttps://www.thirdgen.org/forums/attachments/tpi/88764-highly-modified-tpix281400x-c-documents-settings-owner?d=1109706323mmmmmm.
Old Apr 5, 2006 | 06:59 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
I used a drill with a metal "rasp"to take the majority of the material out, then a ship load of 60 grit sanding rolls and a dremmel tool . then finished of at about 120 grit at the end. i used the bigger runner gaskets and matched it all to my ported edelbrock base. pulls to at least 6k now hope this helps by the way they make an extention that goes on a drill, to get down in the runners pretty good
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
