Vacuum line diagram
Old Apr 3, 2006 | 09:09 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Vacuum line diagram
Does anyone have a routing chart for the vaccum lines under the backside of the plenum. I got a super loud hiss, crappy idle and narrowed it down roughly with some ether.
Old Apr 3, 2006 | 10:00 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
There should only be 3 lines coming from back there. The one to the brake booster, the one that Ts in with the a/c from the underside on the pass. side, and another that ties into the throttle body.
Old Apr 3, 2006 | 10:24 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Half wrong . You have your brake booster, the Check valve, and the Fuel Pressure Regulator. There are also 2 lines running off of the EGR silonoid (sp) The bottom one goes to the underside of the TB and the upper nipple goes to the EGR valve. From the Plenum to the check valve, you have a line going to your HVAC and another going along firewall slicing off to the cruise control servo and the vacume canister under the Charcoal canister tray.
Old Apr 3, 2006 | 10:42 PM
Car: '87 Trans-Am
Oh yea, I forgot about the emissions locations exactly...eliminated most of mine. But he said his was toward the back of the plenum so I thought there were only 3 nipples off the plenum there...though he does have the egr lines and such there to deal with.
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
