What plug gap do you run with aftermarket coil?
Old Apr 5, 2006 | 12:35 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys what plug gaps are you running with something like an Accel supercoil or equivalent? It looks like the stock TPI plug gaps are only like 0.035. I think I gapped to 0.055 or 0.060 last time I did plugs, is this way too much?
Old Apr 5, 2006 | 04:26 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
I'd stay at 0.035. Nice Ride man. what year is that a 81, was that a v6 in the past life?
Old Apr 5, 2006 | 05:04 PM
Car: 2000 BMW M5
It's a 77, it was originally a 305 auto but is now a 327 with a Holley Stealth Ram controlled by a MAF TPI computer that I burn chips for w/ a world class T5 trans. I wonder if my way too wide plug gap is causing the rich smell at idle that I can't get rid of no matter what I do to my MAF or O2 tables. Come to think of it I always gapped the plugs this wide even when it was carbed w/ HEI. Hmmm...
Old Apr 5, 2006 | 05:34 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
if you are using an msd box and higher output coil, you can gap em that wide.
but honestly it's a trial~n~error type of thing
you can start at 40 and increment from there to test it
sometimes going with a large gap can cause run on, or kick back
gap will also depend on compression, cam, etc...
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
