possibly a computer shot??
Old Apr 5, 2006 | 08:08 PM
bigtom88transam's Avatar
Car: 88 trans am, and 06 focus DOHC
Engine: 305 tpi
Axle/Gears: 4.56 screaming pave eating :-)
my car keeps dumping fuel into the injectors and causing it to blow out the exhaust with loud shots... all the sensors are fine but engine light is on still and noticed a pool of fuel in the air cleaner box... i was thinking will the computer keep the injector ports open all the time to cause this?? was thinking the computer is bad most likely?
Old Apr 5, 2006 | 09:03 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
sounds to me like 1 or more of the injecotrs are stuck open
Old Apr 6, 2006 | 04:21 PM
Engine: 305 tpi
could be but doesnt the computer usually tell the injectors to open and close
possible that computer not seeing this??
Old Apr 6, 2006 | 04:35 PM
8UpAFord's Avatar
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
whats the code homes that KEY to fixing your issues
Old Apr 6, 2006 | 04:41 PM
Engine: 305 tpi
well i put it on a snap on scanner and says exhaust is running lean which it isnt... theres a brand new tps sensor and o2 on it...the maf sensor running normal... only thing i can think of thats keeping the injectors open is the computer
Old Apr 6, 2006 | 07:12 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
lol
Computers wont fail and keep the injectors open, the injector driver(in the computer) fails and the injectors close.
Ohm the injectors first. If factory they should be 16-17 ohms, any less than 12 are unserviceable according to GM.
If u find any drastic differences like less than 12 ohm you are looking at replacement.
What you are describing sounds like a cold start injector or injector failure from a leaking injector.
Also check the switch for the cold start injector to see iof it staying on the entire time or comes on and shuts off.
Finally, prime the pump and IMMEDIATELY after doing so block the return and feed lines. U should have no bleed down or very very slow bleed down. If u find any, pull the entire fuel rail and repeat the test with some paper towel under the injectors to help spot leaks.
later
Jeremy
gta892000
Aug 11, 2019 11:16 AM
1MeanZ
Dec 18, 2015 05:39 AM
Amillionoh7
Sep 11, 2015 11:36 AM
fasteddi
Sep 10, 2015 09:32 AM
Street Lethal
Sep 7, 2015 01:09 PM
