Upgrading Fuel Lines for Hi-Revving Motor
Old Apr 7, 2006 | 01:20 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
OK currently I have a 406 with a miniram. I run her up to about 7000 rpms and no problems yet. I have the stock fuel lines with a Holley 255 in tank pump and 36lb SVO injectors.
The problem comes with where the lines are routed. I have Hooker Super Comps and Mufflex y-pipe. The stock fuel lines pass within an inch of he exhaust on the driver's side of the tunnel. I want to re-route the fuel lines but am not sure exactly what to use.
Should I keep using the Helley 255 pump in the tank or should I go with a bigger pump?
Should I keep the stock fuel filter in place and just run larger lines from that point up to the motor and back routed away from the exhaust?
I know I need to re-route the lines. No question about that (fuel pressure regualtor gets too hot to touch) But what size lines should I go with?
Has anyone done this?
Old Apr 10, 2006 | 12:03 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
anyone at all?
Old Apr 10, 2006 | 12:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Now need to reroute just use some heat wrap.. I have pretty much the same setup...
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Elliswon
Aug 10, 2015 12:33 PM
