MAF burn off & power relay plugs
Old Apr 12, 2006 | 06:57 PM
joejoe's Avatar
Car: red one
Engine: on the floor
Transmission: next to engine
Axle/Gears: the ones that turn
I was needing to know if there is any place to get a replacement plug for the MAF burn off, and power relays? mine are in realy bad condition, and I was wanting to replace them if I can. did a search and did not find what I was looking for.
or any other advice on how to repair these would be helpful.
thanks,
joe
Old Apr 12, 2006 | 07:17 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Whats wrong with them? If the connector is greasy looking inside, thats normal, thats what keeps the moisture from corroding the contacts.
Old Apr 12, 2006 | 07:52 PM
joejoe's Avatar
Car: red one
the wires going into them are frayed and some of strands are broken, and the plug itself must have goten to hot.
Old Apr 12, 2006 | 08:13 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
Are these for your 86? If so, we carry them, they are at the top of the page here: Harness Repair Connectors
GM filled these with electrical grease from the rear where the wires enter the connector to avoid corrosion. The later models had a sealed oval relay connector which eliminated the need for using grease.
Old Apr 12, 2006 | 08:43 PM
joejoe's Avatar
Car: red one
thanks, grate place to get parts from,(I needed to call you about something else anyway.)
thanks again,
joe
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
89GTAOz
May 16, 2020 09:31 AM
Bert87
Aug 23, 2015 03:50 PM
Bryan F
Aug 18, 2015 02:28 PM
