whats is the difference between tpi and tbi distributers
Car: 91 formula
Transmission: t5
yes i have searched and i couldnt come up with anything good
basically i bought a l98 to replace my l03 and the guy tookt he distributer... what do i need to change on mine to make it work ? if it helps im keeing my tbi harness and converting it to a tpi harness
Car: 2000 BMW M5
No difference. There were 2 distributors, the large cap and small cap computer controlled dist. The small cap dist uses an external coil. The small and large cap use a different plug so you may have to splice it if you are going from one type to the other, otherwise if you are staying with the same style dist that your harness uses there is no difference.
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
The only one that is different is the truck TBI. There is an inherent rev limiter built into a factory issued truck TBI ignition module. Other than that, yep, all the same.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Does anyone know the number that would be on the truck module?
I have a box of junk yard distributors and don't know whether they are tbi truck, tbi car, or tpi.
Thanks,
Ron
Thanks,
Ron
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
