Half power to fuel pump need help!!!!
Old Apr 18, 2006 | 04:58 PM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
Alright I have access to the fuel pump. I checked the wire that sends direct power to the pump and my test light has a faint light too it like the pump doesn't have enough power to it. I was wondering if anyone can give me the exact locations of the relays on the car. I want to check the power going in and out of the relays. If there is anything that anyone knows that will help me out I would give great thanks. I have a 87 TPI 350. Please help soon I am working on it right now!
Old Apr 18, 2006 | 05:01 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Relays should be on the drivers side firewall to the right (outside) of the brake booster.
Old Apr 18, 2006 | 05:05 PM
Engine: 5.7 Liter
Is there a chance that one of the relays are bad?
Old Apr 19, 2006 | 08:47 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
sounds like you might have a bad ground
Old Apr 19, 2006 | 10:14 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
I did some checking and it looks like the fuel pump relay is the center one of the three on the drivers side of the firewall. If you are standing infront ofthe car looking at the engine bay, the on to the farthest right will be the MAF relay, th next one to the left if the fuel pump relay and the farthest left on is th MAF burn off relay. I would test or replace the relay (they arent very expensive IIRC) and if that isnt it, its probably a bad ground somewhere or a shorted wire. You are checking the power wire before the pump right?
Here is a pic of the fuel pump wireing diagram.
Hope that helps.
Old Apr 19, 2006 | 08:33 PM
Engine: 5.7 Liter
Thanks for the help guys I replaced the fuel pump and she fired right up!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
