fuel pump staying on extra long after ignition shutoff?
Old Apr 19, 2006 | 10:12 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
after i turn off my car, my fuel pump stays on, i know its normal for it to do this, but a lot of times it seems to stay on EXTRA long, like a good 30 seconds after i turn off the car..... what do you guys think this has to do with?
my idea: maybe a wire cross between the fuel pump relay, and the MAF burnoff relay, since after ignition shutoff, the MAF burnoff relay gets power, and goes through a cycle to burn off the access carbon on the MAF sensor
Old Apr 19, 2006 | 12:42 PM
bigchief's Avatar
also, i have a non-adjustable fuel pressure regulator.... i've already replaced it once b/c my fuel pressure was NOT holding after ignition shutoff. the pressure would drop IMMEDIATELY after i turned off the car, instead of holding pressure like it should have.
Old Apr 19, 2006 | 12:56 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Oil pressure sending unit it going out if the Fuel pump stays on that long. The OPSU controls the pump and when it reads X amount of oil pressure it keeps the pump on.
Old Apr 19, 2006 | 01:19 PM
bigchief's Avatar
really??? thats def. weird b/c i have a brand new sending unit in there.... i know that means nothing, but thats weird
9192camaro
16
Feb 3, 2019 12:21 AM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
