TPI cold start problems
Old Apr 20, 2006 | 10:41 PM
91RamAir Formula's Avatar
Car: 91 Formula
Engine: 383 HSR
Transmission: 5th 700R4
Axle/Gears: 3.89
did anyone read the what's your problem section in this month's car craft? There is a great section about TPI distributor problem from 87-92. They are supposidly notorious for cracked reluctors and bad pickup coils causing hard starts, steady misfire, intermittent misfire, surging, bucking and more. You have to remove and disassemble the distributor to find these cracks because the reluctor is part of the shaft. It says rebuild the distributor with a new shaft and pickup coil. More details about this can be found in the problems section of June 06 car craft. Hope this can maybe help some of you out I have seen alot of these problems posted and I my self have had these issues intermittantly, maybe this is the solution.
Old Apr 26, 2006 | 08:58 AM
Vader's Avatar
Good to hear that Car Craft is catching up - That information has been posted here for years. As long as the SEACRH function is working, it is always available.
Old Jul 9, 2011 | 02:58 PM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Re: TPI cold start problems
My '89 5.7 has hard start + surging issues when cold only..any suggestions?
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
