help with heads
Old Apr 21, 2006 | 03:27 PM
cammed91's Avatar
Car: 1991 Pontiac Trans Am
Engine: 350 HSR, Cam, ignition, headers
help with heads
if i were to put in comp cams 08-432-8. it has a vavle lift .510 intake and .520 exhaust with a duration of 230 and 236 @.050 lift, what would i NEED to do to the heads to be able to accept this size cam. i already have to new vavle springs for the cam but i need to get the spring pockets enlarged. i was also thinking that i would need screw in rocker arm studs. correct? is there anything else that i would need to do to make this cam work in my L98 heads. any info you guys can give me would help. thanks
Old Apr 26, 2006 | 09:38 AM
Vader's Avatar
You'll also need to cut down the top of the valve guide seal areas for spring retainer clearance.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
