86 base on 89 heads??
Old Apr 22, 2006 | 11:55 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Hey guys I have a buddy buying my 89 L98 (iroc iron heads) motor to use in his 86 corvette which also has iron heads. Is the angle of the center two intake bolts the only thing he will need to f--k with? Am I correct in the info saying that he can modify his tpi base to work?
Old Apr 26, 2006 | 09:59 AM
Vader's Avatar
AFAIK, you'll have to elongate the two center intake bolt holes on each side, and use some sort of tapered washer or machine the surface to get correct bearing under the bolt heads.
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
89-S-dime
Aug 12, 2015 11:57 AM
