setting engine idle
Old Apr 27, 2006 | 05:18 PM
CarterCarbureto's Avatar
Car: 1987 Z28 camaro
Engine: 305 V8
Transmission: auto
Axle/Gears: 10 bolt pozi
setting engine idle
well I know my car idle's to high, it idle's around 1000-1500 rpm in P
is it just as simple as adjusting the screw on the throttle body?
I read some where that its a bit more complecated. also what rpm should the car be running at? its a 1987 Z28 camaro, with a 305 tpi
Old Apr 27, 2006 | 06:09 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I believe there's an article about this in the Tech Article section. A search will work too.
The screw worked for me. You may need to clean out the IAC (Idle Air Control) valve too. You'll need to do some research on that one.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
