Revs by Itself when i ....
Car: 93 z28
Engine: 350 lt1
Transmission: 4l60
Axle/Gears: ??????
when im driving 50 mph + and let off the gas it drops down to 1k RPM then raises back up to 1500rpm until i cometo a complete stop but idles just fine!!! wtf could be the problem??
i have a
1986 Iroc Z28
5.0L TPI Air Foil Edlebrock Headers Magnaflow Cat 80 Series Flowmaster 3 inch pipes. 1 outlet sounds deeper... took off all AC, Heating Parts and Smog ****
700R4 With a 3,000 Stall Art Car, Reverse Manual Valve Body Ratchet Shift B&M Megashifter
posi rear end 3.89 gears
Einghbach Lowering Springs
i have APC racing bucket seats installed
Blackout Taillights
i have a1986 Iroc Z28
Blackout Taillights
Car: 1992 Camaro Z28
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Just as Im re-reading your post Im now thinking it is not your IAC. But anyway IAC stands for; Idle Air Control. It is a motor operated valve. When the car is idling the blades are closed, depending of conditions that the ECM sees fit, it will open or close the IAC, to ensure a smooth idle. Are you positive it is not the tranny just downshifting, you are letting off gas and allowing car to slow down. In my experience with a good 700r4 they are smooth opperating and the downshift is not too apparent if your not anticipating it.
Engine: 5.7 LT1
Transmission: 4L60
Axle/Gears: 3.23's
Oh wait hold on I just read all of the mods you have done. Your 3000 stall sounds a bit much for a stock cammed 5.0 motor. I have a feeling that your stall is too high.
RedLeader289
May 28, 2019 01:47 PM
