Does anyone out there know where I can get......
Old Apr 29, 2006 | 09:08 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Im looking for a set of vacuum lines for a tuned port 350.. Its an 86 Trans Am and the old lines are pretty brittle and could use a replacement... Any info would be appreciated..
Old Apr 30, 2006 | 01:18 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
You should be able to just remove one vacuum line at a time, note the inside diameter (ID) & the length, then (after you've gotten the total length for each ID size you'll need) go to your local Autozone or Lowe's home-improvement store & buy replacement vacuum lines. AFAIK, there's not a "kit" to replace them all, but it should still be pretty inexpensive.
Hope this helps!
Old Apr 30, 2006 | 03:50 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
If you're talking about the hard plastic formed lines, dealer is probably your only bet. I got away with using regular hose in some spots, but others you would probably need the proper formed line. Unless they are cracked or something though, the hard formed lines should be ok to reuse.
Old Apr 30, 2006 | 07:18 PM
Copchaser's Avatar
thanks guys.. I appreciate the input.. im on it
Old Apr 30, 2006 | 08:47 PM
Vader's Avatar
Your other option is to purchase a length or roll of the hard nylon tubing (available at many parts stores) and heat/form it to the shapes you need. A heat gun is ideal, but I suppose a hair dryer would even work.
Old May 1, 2006 | 09:40 PM
Copchaser's Avatar
not a bad idea there.. I might actually go with that and just adapt each of the connecting ends to the new lines.. Thanks Vader.
88fastgta
Apr 4, 2010 04:36 PM
project86ta
Feb 27, 2006 08:14 PM
