tpi ecu question
Old May 4, 2006 | 10:22 PM
Really-Slow-RS's Avatar
tpi ecu question
i am going to put a tpi motor in my camaro, can i use a stock ecu and build a tpi 383, do i have to have a chip made for the ecu or do i HAVE to go with a F.A.S.T. ecu?
Old May 5, 2006 | 01:01 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Stock ECM and properly programmed chip for startup/cam break-in. Stock injectors won't feed a 383.
Then you'll have to fine tune it to get the most out of it.
Old May 6, 2006 | 07:00 AM
Vader's Avatar
By your question, I presume the car doesn't have a TPI now, correct? If so, and you have TBI, you can perform some rewiring and install a TPI/ECM. A stock TPI PROM for a 350 may run the 383, but you'll need a custom tune. Even if you install larger injectors for the 383 (and you probably should) it will benefit greatly from reprogramming.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
nuggie
Aug 25, 2015 01:27 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
