This cam power loss or gain??
Old May 8, 2006 | 05:08 PM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I have a brand new cam and lifter set setting in my building. My car is a 87
z28 auto with the 305 tpi engine. The cam is a summit racing 204/214 @
.050 int/exh, .420/.442 lift. It says the rpm range is 1500 - 4000 rpm. Would installing this cam be worth it or would I lose power? Thanks.
Old May 8, 2006 | 05:24 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
as far as numbers go, the cam has more lift and more duration, so it would have more power, not alot more though
Old May 8, 2006 | 09:32 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
not without a tune it won't. and also you need a roller cam, the one you're looking at is probably a flat tappet cam. I have that cam in my carbed 305.
Old May 8, 2006 | 10:02 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I have the summit TPI cam in mine. Havent had a chance to finish it yet but it will be an improvement from what I had. Yeah you need to make sure that you motor is roller or flat tappet befoer you order a cam for it.
Old May 9, 2006 | 11:45 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
It's actually smaller than the stock 1989 cam . It had a 207 intake duration@ .050
lt500r55
Sep 1, 2021 01:30 PM
theshackle
Sep 17, 2020 08:26 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Bradsaundry
Aug 12, 2015 12:34 AM
