10243880 -with 87 350 tpi
Old May 9, 2006 | 09:03 PM
Ughh61's Avatar
im new to all this sooo
will this 87 tpi set up work on this block (10243880)
with the vortec heads
or what willl i have to do to make it fit like other heads
Old May 9, 2006 | 11:57 PM
skidude's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 5.7 TPI, L98
Axle/Gears: 3.42:1
stock base will not fit vortec
You'll need to replace the manifold base to use the TPI on Vortec heads. Check out SPDC, Edelbrock, ASM and Accel. You can plan on spending $300 to $400 on one of these unless you get a deal on a used one.
Some folks have modified the stock base and/or the Vortec heads to work together. You may want to do a search on that.
Old May 10, 2006 | 07:01 AM
Ughh61's Avatar
isnt the ports to big on the vortec or am i thinking about fast burn heads
Old May 10, 2006 | 10:20 AM
skidude's Avatar
Axle/Gears: 3.42:1
vortec has taller ports
Yes. The ports on the Vortec are taller. The stock base manifold will not match the Vortec ports that well, but some people have made them work. Its not my reccommendation though. I would buy the aftermarket base.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
