EMISSIONS
Old May 11, 2006 | 10:58 PM
chevyman_89's Avatar
EMISSIONS
I have a 85 iroc-z and i was wondering if i can take out any emissions stuff without messing everything up.
Old May 11, 2006 | 11:17 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Hey, and welcome to the forum! This topic is widely discussed daily and an answer can be found by using the search feature and typing in "emissions, pass inspection, AIR system", etc, things of that nature.
You won't mess anything up by removing it, but what you have to worry about is inspection. If you live in an area where that is not an issue, then you are fine. Some people on here have claimed that they can still pass by taking out the smog pump and the AIR tubes.
Old May 11, 2006 | 11:19 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
removing the smog pump , cat and stock air box shouldnt mess with the computer to get a check engine but will become in some states a illegal smog car and will fail state emissions testing so far ive pulled the a/c , smog pump , smog lines and the cat = NOTHING BAD YET lucky enough only fines in michigan are for cars burning oil severely not for smog testing
Old May 11, 2006 | 11:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As I always say, removing your emissions equipment is a FEDERAL offense, punishable by a fine, jail time, and/or both, if you get caught. Even if your state or locality doesnt have emissions testing, its still illegal to remove it. Also, we hot rodders get a bad name already by the general public, so why add to it with this?
Old May 11, 2006 | 11:43 PM
Car: 1985 TransAm
Engine: 5.0L TPI
how would they catch you? like taking it in to a midas or something they'll call cops or something? i though they just wont service your car....
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
