can i?
Old May 12, 2006 | 08:23 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
can i?
i need a little more room under the hood, and was wondering if anyone has removed their evap canister... can i just disconnect it and drop kick it accross the shop??? and will it set the check engine light if i remove it??? any help or idea's would be greatly appreciated...
Old May 14, 2006 | 10:42 AM
Vader's Avatar
I'm not certain, but on a '91 ('747 ECM?) you may get an error code. Either way, you're going to have to deal with fuel tank pressure control somehow. You could get a later style EVAP canister from a GM vehicle and mount it under the car (like the later units are).
Old May 14, 2006 | 08:25 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Thanks Vader!
Old May 14, 2006 | 09:00 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
You should be ok, just buy a vented gas cap. I took mine out of my 87.....yeah I kicked it pretty far! No codes at all. But like Vader said check it out. I'm not sure 100%
