HELP PLEASE! WIth AC Delco part number
Old May 13, 2006 | 01:17 AM
Francis's Avatar
HI all, does anyone! know what type of injecotrs these might be.
I know they are the AC Delco style and here is all the info off them.
10108480
3358
CAV
5720D 780
I need to know the LB if someone can help.
Thanks.
Old May 13, 2006 | 01:28 AM
Francis's Avatar
I went to the Ac delco site and did a parts listing search on both the 86 305 and the 87 350.
I found this under the 87 350 listing
08 217-231 INJECTOR KIT,M/PORT FUEL
Second Design REQUIRES O-RING P/N 217-1379
LUCAS)(ID BY CAV ON SI OF INJR)(FOR 1ST DES SEE 17111961
The (ID BY CAV ON SI OF INJR) is what is on most of mine. (as they have failed I have replaced them with what I thought was the right style and used 19LB bosch ones.) So I'm thinking this means that my 305 had been set up for larger 22lb ones. does that sound right?
Old May 13, 2006 | 01:34 AM
Francis's Avatar
So from here what do you think I should do? I have a mix of both Bosch 19Lb ones and AC deco 22Lb ones and! I have those second hand 19LB ones coming from Canada.
my options are:
1: Should I look at just getting a new set of 22lb ones and get you to changes that chip to run them on a 305?
2: Keep the Hypertech Chip in and get new 22LB ones (also what's your thoughts on those chips, do those chips really make a difference anyway?)
3: Install the 19lb injectors when they get here and use the chip you made me as is?
What would be the best way for most power and reliability?
Francis.
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
