Fan switch / Water temp sensor Question
Old May 14, 2006 | 05:10 PM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Can I put the fan switch, that usually goes in the passenger side block, in the front of the intake manifold? I'm using a 90-92 Camaro TPI setup.
I can't use it were it should go because of the headers. I had to get a pipe bushing to make the sensor fit into the block and it sticks out pretty far.
Old May 14, 2006 | 08:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Yes, but you'll then need to find a place for the CTS to go.
Old May 15, 2006 | 05:17 AM
techno101's Avatar
Car: 1989 Camaro RS
I left the CTS where it was, and put the fan switch in the hole right next to it. It is right under the heater hose bib. Is this ok????
Old May 15, 2006 | 08:02 AM
Vader's Avatar
Sounds as if you installed the fan switch where the cold start control would have mounted on an older TPI. Should be just fine.
Old May 16, 2006 | 05:05 AM
techno101's Avatar
Car: 1989 Camaro RS
I'll try and get a picture of it soon, thanks for the help guys!!
Old May 16, 2006 | 05:13 AM
techno101's Avatar
Car: 1989 Camaro RS
Ok heres a pic, do you think this will work??
Attached Thumbnails Fan switch / Water temp sensor Question-water-temp-sensor.jpg
Old May 16, 2006 | 10:05 AM
Vader's Avatar
Provided you can attach the connectors, it should work just fine.
Old May 17, 2006 | 05:10 AM
techno101's Avatar
Car: 1989 Camaro RS
cool thanks for your help!!
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
TA8487
Aug 16, 2015 12:21 PM
bamaboy0323
Aug 15, 2015 07:20 AM
