running sluggish
Old May 18, 2006 | 07:44 PM
3rdgenlove's Avatar
running sluggish
i recenly rebuilt the engine in my 89 camaro iroc z and have lots of experiance with that aspect but am not with the sensors and all that i have the tpi but something is not right when i let off gas it has a shake i was told by someone that it might be the mass air flow sensor or another sensor but i dont know where to start
Old May 18, 2006 | 08:57 PM
3rdgenlove's Avatar
if thos symtoms dont help much i have some more deatailed ones it has a missthe bottom end rpm is vey jerky and surgy and i know its a v8 but its very very bad on gas like a trip across town not taking it ez but not abusing can take about 1/4 of a tank of fuel
Old May 18, 2006 | 09:21 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Did you make sure you set the timing in the correct manner? assuming it has the stock engine it would have been a tpi motor. To set the timing correctly, you need to disconnect the EST connector on the passanger side of the engine in the wiring harness. It will be the connector on top of the heater box, with only one wire in and out, Start the car, and then set the timing to 0* TDC. (That's what my tpi calls for on the underhood sticker. If you are sure thats not your problem, check that you got the firing order right. (Spark plug wires on the correct spark plugs.)
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
