What do I need to switch rear ratio?
Old May 21, 2006 | 08:29 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I have a 1989 Chevrolet Camaro IROC-Z with 2.73 POSI rear with discs. Let's say i would like to go to 3.42, what do I need? Ring and pinion only or other stuff too? I'll probably buy used... Do all years will fit?
Thanks!
Old May 21, 2006 | 08:46 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
First off you have a 9-bolt Borg Warner 2.77's right?. Other bw ratios include 3.27's,3.45's and 3.70's. The only ones still re made are the 3.70's. To go to a [lower] ratio you will need a 3 series carrier. Pretty sure randys ring and pinion still sells them. I also know that 9 bolt.com use to sell used 3.27's and 3.45 9 bolt gears. The sites been down for awhile though. Maybe try a junk yard or post in the parts wanted section of this forum. Good luck.
Old May 21, 2006 | 08:51 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
No it's a 10-bolts with 2.73, not 2.77...
Old May 21, 2006 | 08:55 PM
Car: ws6
Engine: ls1
Transmission: m6
You lucked out then. Summit racing sells the 3.42's, and the install kit i believe.
Old May 21, 2006 | 08:57 PM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Do they sell to Canadian people?
That's why I wan't to buy a used set... Any mechanic have the tools to install that or I should bring him the kit you're talking about?
Old May 22, 2006 | 07:02 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Info:
You have a 2-series carrier and want to use a 3-series gear set. Standard gear sets will not work, you will require a spacer or thicker gears, .
Old May 22, 2006 | 09:37 AM
WaOnFiRe's Avatar
Engine: 5.7L
Axle/Gears: 2.77
Is their any place that sell thicker gear for 2 series carrier?
Old May 22, 2006 | 11:42 AM
DJP87Z28's Avatar
Yes, but off hand I can not name one. Someone will give you that info.
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
MORREALE5
Sep 13, 2015 09:16 PM
hectre13
Aug 26, 2015 08:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
