Cracked rotor
Old May 23, 2006 | 06:29 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Cracked rotor
my new replacement rotor fell on the floor and a chip near the metal piece on the side wall of it chipped of
was wondering if it would make the spark arc or something? because the idle and stuff seems worse then before.. i replaced it and the cap because of only 4000 volts to cyl 6 and 8
Old May 23, 2006 | 06:54 PM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Theyre cheap enough that Id replace it. Cap and rotor are pretty important to make sure they are in near perfect condition.
Old May 23, 2006 | 06:56 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
there brand new, Problem is replacement one fell on the floor real quick
it just cracked a piece on the side wall
Old May 23, 2006 | 07:21 PM
Car: '87 Trans-Am
Yea, thats what Im saying, if it got damaged at all, I would replace it. Its cheap and not worth chancing.
Old May 23, 2006 | 08:28 PM
Vader's Avatar
Without a doubt, the rotor falling on the floor more slowly would be preferable. Perhaps moving to a location with a lower gravitaional attraction would be advantageous. Or, carpeting the garage could be a temporary safeguard until you can arrange the relocation.
In other words, bite the bullet and get another rotor. If it's more of a scratch than a crack, it might be servicable. Have a photo?
Old May 23, 2006 | 09:10 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
lol Nah but lemme draw something in paint hold on! nvr mind imt to ghetto/dumb to uppload it either way bassicly u know the wall around the thin metal strip the circle one, well a big chunk of it cracked out.. Im guessing like most times gm didnt put the cirlcular wall there for no reason so therefore.. guess ill be buying a new rotor
Old May 23, 2006 | 11:51 PM
Vader's Avatar
Yeah, a new rotor will be safest. About a lifetime ago, I had a Cadillac towed off the tollway when it died coming out of a toll booth. It was about a $150 tow bill to go a couple miles (just to get it off the interstate) for a $4 rotor that broke down the middle. Freakiest thing that I ever had happen, and I don't think I dropped it (it had run over a year with no problems - it just let go).
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
tyeo098
Nov 30, 2015 06:27 PM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
the_hamturdler
Sep 22, 2015 02:59 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
