RR ratio in powerband question
Old May 24, 2006 | 10:58 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
I'm considering the purchase of a new set of roller (or roller tip) rocker arms to use with my new ZZ4 cam (.474/.510 using 1.5rr).
I know if I use 1.52rr, it will change the lift to .480/.517.
If I use 1.6rr, it will change the lift to .506/.544.
What I am wanting is maximum low-end & mid-range torque (and HP if i can get it, but I have more fun with torque )
Can anyone tell me how, if I use a ratio higher than 1.5, my cam/engine would respond? Will my powerband be impacted?
FYI - I plan on using Dart Iron Eagle 180cc, 64cc cylinder heads.
Any info would be greatly appreciated.
Thank you!
Old May 24, 2006 | 11:25 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
You will probably pick up 10-15 ft-lbs and hp across the board.
Old May 24, 2006 | 11:51 AM
That sounds great!
Going to .506/.544 (using 1.6rr) seems like a big jump.
I know the factory cam lift is .415/.430.
Do I need to worry about valve clearance going to a ZZ4 with 1.6rr?
Old May 24, 2006 | 12:27 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I agree. You really only need to install the 1.6 rockers on the intake side.
Old May 24, 2006 | 12:49 PM
But if i only did the intake side, that would be .506/.510.
Would that mess up my low/mid-range torque goal?
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
