slp cold air
Old May 25, 2006 | 06:22 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
slp cold air
i'm sure someone on the site has installed a slp cold air on thier tpi car. I will be installing one soon (its on order) but i'm going out of town so it wont be installed for like a week. just wondering what difference it will make to times. So far my car has a air foil, AFPR, underdrives, and some timing and has gone 14.33
(the car will also get a Random Tech after cat and a B&M converter soon, i like testing each part by itself)
Old May 25, 2006 | 08:09 PM
subliminal's Avatar
Ive never used a SLP one but I made one myself for my old car and I could really feel a difference. You can also hear the engine actually sucking in air like it should . You could of made your own too for about 3/4 less than what the SLP one is theyre way overpriced.
Old May 25, 2006 | 08:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
guy at the track i race with has one on his car. its a big improvement over the stock piece but still leaves some to be desired. those formulas are hard to get air flow to without making a custom nice smooth piped intake setup or convert to speed density and have the open element and ram air hood
Old May 25, 2006 | 09:46 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I have one and have installed it. I love it it was a great add on with my full exhaust. My motor can finally breath. Yeah whoever designed that stock set up on Pontiacs is a little
I have nothing but good things to say about SLP....But you get what you pay for. All the rubber boots all have a metal piece in them to allow the air to flow really good. You wont be dissapointed at all!
Old May 25, 2006 | 10:35 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Not trying to jack this thread, but if one were to make a cold air intake, where would be the optimal position to have the inlet to the intake? I like how the stock intake for the TPI on camaros get access to the fog light ducts, but I've seen some guys put them in place of their battery, and I have trouble visualizing how you are getting optimal airflow in that area.
Old May 26, 2006 | 06:25 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
in all honesty the SLP kit is nice, and makes a nice addition espeically if you want to have a pretty show type of car
but
i think you can get away with using a K&N 3.5" cone type of filter in place of the stock air box
heck of alot cheaper and easier to install
and i bet it will breath better too
wont be a real true cold air kit, but it will definitely help alot
Brinkkl2000
Aug 4, 2018 08:29 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
stalkier
Dec 6, 2015 11:25 PM
jimmy harris
Aug 31, 2015 03:09 PM
kyle5647
Aug 15, 2015 11:56 PM
