86 ta hop ups
Old May 25, 2006 | 09:27 PM
86ttopta's Avatar
86 ta hop ups
Could anyone give me a list of what they thing are the best bolt on parts for an 86 trans am with TPI and 700 r4 transmission and borg warner posi traction rear end with 2.73 gears
Old May 26, 2006 | 05:02 AM
Vader's Avatar
If you have the Borg 9-bolt axle, the ratio is actually 2.77:1.
Forget about an airfoil or larger MAF for the 305.
Exhaust system modifications really never hurt, but won't make a big difference without better basic airflow. The engine runs out of breath at 4,500 RPM, when a larger exhaust would really make a difference.
The biggest restriction on this engine is the cam. Higher ratio rockers make almost no difference.
Better valve springs also help, since valve float is one of the things that kills power at or about 4,500 RPM.
Reprogramming is always worthwhile, but don't bother with any "cookie-cutter" PROMs such as HyperTech.
If you use any ethanol blended fuel, don't lower the thermostat to anything below 180°F, and don't bother bypassing the coolant line at the throttle body.
The intake air filter "garbage can", ductwork, and resonator box can be restrictive. That may be worth looking into.
Old May 26, 2006 | 11:42 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
check the sig, when I got my car I was in the same boat as you.
Old May 26, 2006 | 12:17 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Dude, WHY do you never ?
Vintageracer
Sep 24, 2017 12:34 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
IroczFan
Oct 6, 2015 10:13 AM
FreeSpirit
Aug 29, 2015 05:47 PM
