Meatiest Cam that keeps the stock SD computer happy?
Old May 25, 2006 | 11:52 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
I am rebuilding my motor and am getting a cam. But I want something that will give me gains, but will keep the SD system happy. What should I look at. Also, the block will be 350 but the heads will be 305.
Old May 25, 2006 | 11:57 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Probably the production LT4 cam.
Old May 26, 2006 | 12:45 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
just curious how big is that cam and were can you find it?
Old May 26, 2006 | 12:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
idk, a good tune should keep the SD system happy with most any cam... i'm not sure how big u could go without needing a tune. probly not too big. else u wont be seein the gains the cam is capable of.
Old May 26, 2006 | 11:48 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
SD is not very tolerant of modifications on the stock chip, ask any TBI owner. Do yourself a favor and pick the right cam for your motor and gearing and have a chip burnt to match. Dont cop out on a nutless cam just because you dont want to burn a new chip.
this is one of those deals where us MAF guys have the last laugh. I have upgraded cam and heads and exhaust with the stock chip and I think my #s are pretty decent. the chassis dyno shows me fueling pretty accurately, although I could use more timing I am sure.
Old May 26, 2006 | 01:08 PM
robert1's Avatar
How do we find a good person to burn the chip though? I've been hunting around WI, and only found a place a few hundred miles away!
Old May 26, 2006 | 01:38 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Time to buy some chip burning equip!
Old May 26, 2006 | 02:18 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Robert, Im still pretty new at it but eventualy I will helping people out with this. If your interested shoot me a PM and we can figure something out.
Old May 29, 2006 | 09:37 AM
LedHeadRed's Avatar
Car: 1990 Corvette
Engine: 355cid
Transmission: ZF-6 speed
Axle/Gears: stock 3.33
with SD, you probably won't get away with very much change at all, maybe one step up in duration from your factory cam -- and this is only a guess. the post above regarding MAF is true, as fueling changes during partial throttle (ie, up to 80% TPS) are adjusted by the ECM on the fly; SD as you know has the fueling inputs hardwired into the lower fuel table in the chip. in this regard, the MAF guys have it all over us.
when i had my mods completed (with LPE 219 cam, which is 2 full steps up in duration), i had what i thought was a custom chip; the "tuner", who was big on this board about 2 years ago (whose name i won't mention), didn't make ANY fueling changes to the lower table in my chip (verifed by a .bin scan later), and consequently my engine detonated severely. my mistake for not verifying early on. no fuel = ultra lean detonation = top ring land failure. not a good thing.
you MUST have the chip recalibrated, even with mods such as exhaust (assuming long tube headers), on a SD setup. your ecm will not be able to compensate for the change in air/fuel ratio with SD, anywhere near what a MAF setup can.
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
Thirim
Aug 9, 2015 06:19 PM
