roller rockers
Old May 28, 2006 | 01:06 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
roller rockers
Who makes the best roller rockers for our 350's? I was gonna put some 1.6 roller rockers on my iroc to get some more lift out of my cam its a 89 iroc with the .415 .430 lift how much will it improve with 1.6 rr. Also should i go steel with roller tip or full roller and who makes them (links please). What valve springs do you guys recommened for this and is there any other parts i might need? Also is it a hard job to change the rocker arms?
Old May 30, 2006 | 12:04 AM
robert1's Avatar
I'd look for a name-brand that fits, and they'll be just fine. Secondly, it's not too hard if you're mechanically inclined. Remove both valve covers, and install them. Then, turn the engine by hand, setting each one when the lifter is on the base circle of the cam. This is important since you can't adjust them correctly when it's on a ramp.
Old May 30, 2006 | 01:36 AM
LT1Formula's Avatar
Best for me is Comp Cams Pro Magnums.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
